Bullitt
PC Specification: Win7 Ultimate 64-bit
Sony Vegas AVI no Sound
Sun Feb 08, 2015 2:00 pm
Hi
I have recentlymigrated from FRAPS to Action but I am having a couple of issues.
Firstly when I record in AVI format I get no sound registered I can hear the sound via Action playback or using a media player but not in Vegas. The versions I have tried it in are Movie Studio HD Platinum 11, Vegas Pro 11 64bit(trial), Vegas Pro 13 (trial)
I am also getting a problem when I try to record the microphone in a separate audio track it records no mic input at all but if I un-tick this option I can record the microphone no problem at all !
I am hoping these issues are just some settings I need to change but I would appreciate any pointers my PC specs are below thanks in advance.
Operating System
Windows 7 Ultimate 64-bit SP1
CPU
Intel Core i5 3570K @ 3.40GHz
RAM
8.00GB Dual-Channel DDR3 @ 826MHz
Motherboard
Gigabyte Technology Co., Ltd. Z77-D3H
Graphics
ASUS VS247 (1920x1080@60Hz)
3072MB ATI AMD Radeon HD 7950 Series (ATI AIB)
Audio
ASUS Xonar DG Audio Device
Blue Snowball USB microphone
Bullitt
Re: Sony Vegas AVI no Sound
Mon Feb 09, 2015 2:14 pm
Ok I figured the no sound thing out you need to make sure the Allow multi-channel audio recording is un-checked otherwise Sony Vegas will not import sound.
After 2 hours of trial & error simples. ;)
Still not sure about the microphone thing though.
Sir Yucko
PC Specification: FX8350, 2x GTX 970 sli, Win 7
Tue May 19, 2015 1:48 pm
What are your audio balance settings?
Also if you are exporting from Action! and recording your Mic separate then it may be that you are only exporting the system sounds and not your mic. It gives you the option to export either Audio 1 or 2. 1 is the system sounds and 2 is the mic. I wish they gave you the option to include all tracks when you export.
I was having the same issue with multi-channel recordings. But turning that off and recording my mic separate worked for me. I have my audio balance set to 98 for mic and 2 for system sounds. Action! really seems to favor my system sounds over my mic. I could probably turn down my system volume to fix this as well.
But, yeah I think it may be your audio balance, or system settings for your mic. Can you hear your mic just fine when you watch the AVI from Win Media Player?
Return to “Mirillis Codecs”
