deadspeak
PC Specification: intel core i3 530, win 7 ultimate 64bit,
hiding upper menu bar
Tue Aug 23, 2011 7:28 pm
Hi Guys
am using splash as external player for media center, when opening i get the upper menu bar visible on screen, i've set to open app in full screen and play file in full screen, but am unable to hide this top menu, am i missing something?
Thanks
Paul
deadspeak
Re: hiding upper menu bar
Thu Sep 15, 2011 9:17 pm
So i'm guess i'm the only one that has an issue with this?
Thu Sep 15, 2011 9:20 pm
What media center do you use?
Top menu is visible only when mouse is onover.
deadspeak
Thu Sep 15, 2011 9:22 pm
Ghost wrote:What media center do you use?
Using windows media center, with a happauge mce remote.
deadspeak
Fri Sep 16, 2011 5:25 pm
I have splash set up as an external player for mymovies.
if i plug in a mouse, it's shows that is in the far to right hand corner, move it and the tool bar disappears, if i move it to the bottom corner well out of the way, restart media center, launch mkv file this then relaunches splash tool bar is there and mouse is registered as being back at the to right hand corner again!!
deadspeak
Sun Nov 06, 2011 9:28 am
Was hopeing the new version would sort this issue. But no still there, which means the program is unusable, so, so far a waste of money!!
P.J
Fri Nov 18, 2011 10:48 pm
deadspeak wrote:I have splash set up as an external player for mymovies.
I wonder what thing places the cursor at the top left :?
deadspeak
Tue Nov 22, 2011 10:00 pm
no idea, tried everything i can think of, but nothing. Until i can get this resolved splash is unusable for me :cry:
P.J
Fri Nov 25, 2011 11:04 pm
I agree with you somehow. It happens for me sometimes.
Ghost, would you please add a checkbox for it in Settings? :roll:
deadspeak
Wed Feb 08, 2012 11:24 pm
Nearly 3 months with no update.
Any news if anything is in the works?
I really want to use this software but it's still unusable for me. Very frustrating :x
